I just discovered that my 1959 Silver Hawk has a Twin Traction differential (with a 3.54 ratio, as near as I can tell.) If I change the gear lube, are there any special requirements for this limited-slip unit? (Some limited-slip differentials needed special lubricants.) What would work best in this diff? Thanks.
TT Gear Lube
The cheby dealership stuff. cheers jimmijimsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
The GM additive is a fine product. I researched and decided that Valvoline Syn Power Full Synthetic 75W-90 gear oil for Limited Slip should also be fine. You should find that at your local O'Reilly's or Autozone or similar parts store. I assume that if anyone thinks there is a problem with the Valvoline product, they will chime in.
