In reassembling the '63 (OHV) six, I have gently pressed on the cam gear and have it in the block and I'm in the process of plastigage-ing the mains. (To my relief I noticed the flywheel bolts go in from the flywheel side.) I guess I did this backwards by seating the cam gear first but I'd like to figure out a way to get that crank gear back on without using the crank bolt - like the spiffy tool in the manual. My crank bolt has questionable threads on the last inch or so and I'd rather not make it pull that gear on.
Is there a suitable sub you've used? Thanks!
Western Washington, USA
