(289 v/8) I installed a new temp sender when the new motor went in a while back. For a long time my gauge was performing as it should. However, now I am getting sporadic readings. Some times it reads properly (steady 180 +/- when fully warmed up) but sometimes it'll just climb up to 240 (max) and sit there but it isn't running hot) No amount of wire jiggling, tapping, key wriggling or swearing will get the gauge back to normal. When I turn the key off the gauge goes to zero.
As I am technologically brain dead today, I ask... Is it most likely a ground (open)? A short? Something else? Thanks.
