My daughter is considering building a "Tiny House" on a utility trailer. The power (two, separate 20 Amp circuits) will be sourced through RV style cords from a detached, secondary building on the property - once I install exterior outlets. I know that I need GFIC protection on the exterior circuits. I was considering GFIC breakers at the main box, but feel GFIC outlets in the secondary building would be better. I can install the GFIC outlets internally, but feed the protected circuit to to the exterior receptacles. This way a person would be in a dry environment to reset the circuit as opposed to rain running off the roof at the main box with GFIC breakers.
A second consideration comes up if the tiny house is ever moved. While in use as I describe the house would be completely GFIC protected by the external outlets at the secondary building. But, moved there is no guarantee the next supplying power source would be GFIC protected. Therefore, I was considering putting the bathroom and kitchen sink areas in the tiny house on an additional GFIC outlet (internal to the house itself). However, this would result in in one of the 20 amp circuits have two GFIC's in series. Is there any problem in doing this? It seems the prudent thing to do safety wise - if there are no issues with series GFIC's.
To simplify it will look like this:
200 amp main box > 20 amp breaker > secondary building with GFIC (#1) > exterior outlet (connected to GFIC) > power cord to tiny house > tiny house 20 amp breaker > additional GFIC (#2) > sink area outlets
Thank you to anyone who can reply.
