can anyone tell me about how to remove rear axles on 63 Avanti twin track rear end?
Removing axles
Sure: Get the shop manual....CD version if you're current....But seriously, what's wrong with your axles ? Stripped threads ? You'll need to remove tires, pull the hub/drums with special puller, repeat, special puller, remove axle shims, seals, gaskets, and use the drum/hub as a slide puller, look down the axle tubes to see if you've dislodged the friction blocks, use a special hand made tool to retrieve and re-install.....Install in reverse order having packed the rear bearings and set axle endplay (.001-.006). I'm sure I missed something, having doen this procedure quite a few times ........ you need the manual....
