I found a replacement T-86 od trans that so far seems to be in real good condition, but while doing a bench test of the od I discovered a problem that I am would like to get some advice on.
By moving only the od lever on the tail shaft to the rear (od available position) the output shaft would turn about 1/3 faster than the input shaft. I know this because I flagged the shafts. When the solenoid was powered it clicked but did not engage or disengage the od, powered or not. The lever is the only thing that seems to put the od in or out. There is freewheeling when the lever is in the od position. I'm questioning why the solenoid is not switching it in and out of od? Could the sun gears be gummed up? I'm thinking of filling the tail shaft with diesel to see if that might free up something. This trans had been sitting for years indoors and most of the oil had drained out the tail shaft. Your thoughts on this would be helpful, thanks.
