I have a '64 Commander, that I can not shift gears. I can start in any gear, and I can also shift when engine is not running, but I am assuming that the clutch needs replacing. Since I have never done a clutch does anyone have any good advice about what to do or what not to do. I have found a mechanic that will work on it if I can supply the parts--what's the best place to find the necessary parts. I have a local store that will have some of these parts, but probably not all.
I have adjusted the linkage, so I am pretty sure it is the clutch--but it did go out suddenly, so if you have any other suggestions I am certainly open.
Thanks for your help!
Crazy for thinking I can do it myself[
11
11
