V-8 Fuel pump item number?
  • Fuel System: V-8 Fuel pump item number?
    My local Carquest lists their fuel pump # 4227 back to 1955 Studebaker V-8. Should it also fit the '51, '52, '53 and '54 V-8?
    And when did Studebaker move the pump from the oil filler neck to the passenger side of the block?
    Brad Johnson,
    '56 Sky Hawk in process
    The pump moved in 55, along with a redesign of the heads and valve train.
    the 55 and newer pump has a different actuator/arm than the 51-54 pump.
      As I feared. Thanks, Roy.
      Brad Johnson,
        I may have found it at NAPA. It comes in tomorrow morning, if it's correct I'll post the part number.
        2005 Dodge Magnum
        1952 Studebaker Land Cruiser
          You guys may have this but I found this while part surfing.
          Rjtechx/rjparts (reviewed Feb 2007)
          Sep 2009- NOTE: The Airtex 4227 and Carter (NAPA) M2211 are the SAME pump. They both are made
          cheaply, have the pivot pin oil leakage issues and will probably fail within a year. There are numerous
          references to their problems on the SDC Forum.. For a V8, the best bet is to go to an electric pump.
          FUELP --AIRTEX: 65-66..194 & 230 ci......Airtex 6790 /
          FUELP - 62-64..169 ci.....Airtex 4703 / 59-61 ALL.....Airtex 4703 /
          FUELP - 65-66 283 ci........Airtex 40254 /
          FUELP - 39-54 CHAMPION 6cyl(std.mtr)....Airtex 527
          FUELP - COMMANDER-LARK 62-64 259ci........Airtex 4227 /
          FUELP - 59-61 ALL........Airtex 4227 /
          FUELP - 55-58 COMMANDER & PREZ.........Airtex 4227 /
          FUELP - 56 SKYHAWK......Airtex 4227 /
          FUELP - 62-64 289 ci........Airtex 4227 /
          FUELP - 62-64 E7,E12,E13,E28,E40,3E,6E.......Airtex 4227 /
          FUELP - 59-61 E2,E7,E12,E13,E28,E38,E40, 3E,4E..........Airtex 4227 /
          FUELP - 55-61 185 ci & 224 ci 6cyl E5,E10,......Airtex 527 /
          FUELP - 1958 3E7,EB,E8B,E12,E13,E28, E28B.......Airtex 4227 /
          FUELP - 55-57 2E,3E7,E12,E13,E28,28B,E38, 38B,3E40,3E40B......Airtex 4227 /
          FUELP - 1954 169 ci 6 cyl, 3R5,3R10.....Airtex 527 /
          FUELP - 49-53 169 ci 6 cyl, 2R5,2R10.....Airtex 527 /
          FUELP - 47-48 169 ci 6 cyl, M5,M15A,.....Airtex 527 /
          FUELP - 41-45 169 ci 6 cyl, M15........Airtex 527 /
          FUELP - NAPA V-8..... M2211 (Standard, not R-series) Champ 6 -----M958
          FUELP - 41-61 trucks and 39-54 Champion cars Standard 40527
          FUELP - 59-64 six cylinder cars Standard 44703, Airtex AC 4703
          FUELP - 55-64 eight cylinder cars and trucks Standard 44227, Airtex AC4227
          FUELP - 65-66 six cylinder cars Standard 4679000
          FUELP - 65-66 eight cylinder cars Standard 40254
          FUELP - RQB - 81 Fuel Pump - AC 41216
          FUELP - 63 - 64 Avanti R1 / R4 Fuel pump 1557213 Carter M 3509S Carter* 2063 *Require: Some modification
          FUELP - 63 - 64 Avanti R2 / R3 Fuel Pump 1557015 Carter M 35008S
          FUELP - 63 64 R1 -CARTER - #M35095
          FUELP - 259-289 fuel pump Carter-federal Mogul # M2211
          FUELP - 63 Cuiser 289 - AC 4156 or Rayloc 24156.
          FUELP - 41-61 trucks and 39-54 Champion cars Standard 40527 or NAPA M958(Carter) or AutoZone Master 527
          FUELP - 51-54 V-8 - UDS Fuel Pump Part #9647
          ELECTRIC replacement pumps ( Jun 2004)
          NAPA - ECHELIN 610-1050 - is a 12V, inline, solenoid pump, freely
          found in NAPA stores. Lightweight allows you to just let it hang in line with
          the fuel lines. no reliability issues reported yet, although they're chheap
          enough ($49.00 - Sep 09) to buy 2 and keep one next to it.
          Fuel pump (electric) Master E80125 Autozone ( Dec 2005)
          Jan 2007 - 59 Lark - M2211 NAPA
          NAPA - ECHELIN 610-1050 - is a solid state, inline, rotary pump, freely
          enough ($30) to buy 2 and keep one next to it.
          Fuel Pumps
          6-VOLT electric fuel pumps: factory fresh 6-volt fuel pumps with
          1-year factory warranty, fixed pressure 4-7 psi, $49.50 ea postpaid
          ; adjustable pressure pumps, 2-6 psi, $83.50 ea postpaid; brochure
          and information sheets available for #10 SASE; also repair parts for
          AC, Walbro, Dupree, Borg-Warner, Capac and Autopulse pumps. Don McKinsey,
          PO Box 94H, Wilkinson, IN 46186. Nov 2004)
          Mar 2007
          6 Volt electric-
          Car Quest Part #E8011 6 volt Electric Fuel pump. Lists for $99.05 I picked it
          up today for 64.79
          NAPA P4259 (~$110) which comes with heavy duty mounting bracket and fittings. This pump runs very quiet
          (Aug 2007)
          The E8011 (6 volt) or E8012S (12 volt) pumps are solenoid type pumps which can be used in draw thru applications. They are available from a number of suppliers under various part numbers.
          The MAC's numbers are EFP-9350-6 (6 volt) and EFP-9350-12 (12 volt).
          February 2003 Turning Wheels' Co-Operator, with a follow-up in the
          June 2003 Co-Operator, Jim. BP
          NAPA for old Ford tractors, etc.
          NOTE: If you can't find a Stude type V8 pump, buy a 230GM Six unit, of the same Brand, IE Airtex and swap the pump arm of your old with the new. /Turning Wheels, sometime in the 70's
          2005 Dodge Magnum
            I have a rebuilt one laying on the shelf. If yiou don't find one let me know. I have changed my direction on building a 232 for my 53.
              Studebaker moved the pump to the drivers side (left) on their V-8's, the passenger side pump arrived with the Chevy engine in 65.
              60 Lark convertible V-8 auto
              61 Champ 1/2 ton 4 speed
              62 Champ 3/4 ton auto
              63 G.T. Hawk R-2,4 speed
              63 Avanti (2) R-1 auto
              64 Zip Van
              66 Cruiser V-8 auto
                Well, actually, one model did have it on the passenger side in 56.
                Bez Auto Alchemy
                  Mine's working fine now, but Art Campbell's looking for one for his '52.
                  So, is there a part number from Carquest, Advance, NAPA, O'Reilly or any others for the early V-8 fuel pump? Or can we only get the 535701 from SI for $150 with core, or rebuild kits for the ones we have?
                  Brad Johnson,
                    Right Brad! Only the '56 Golden Hawk with the 352" Packard V8 had the fuel pump on the passenger side.
                    '58 Packard Hawk. A partially restored car that was not completely assembled.
                      Well, how many RHD Studebakers had the pump on the passenger side?
                      Jim Bradley
                      Lake Monticello, VA
                      '78 Avanti II
                        We'll my hopes of a NAPA pump for the old 52 were dashed on to the rocks. I may have been able to make it work but decided not to. Tomorrow is a big swap meet at Rhinebeck in Dutchess County I should be able to get something there.
                        2005 Dodge Magnum
