I was returning from a show with my 61 Lark. I put some gas in it. 50 miles later it spit, sputtered. and stalled.. This car has been running like a watch before that. I guessed the gas I bought had water in it. Anyway I had the car put on a trailer to get it home.
I added water remover (heet), changed the plugs, fuel filter, took the carb apart and cleaned it, and checked any ignition stuff.
Now the Lark will reluctantly start with starter fluid, and run awhile, then quits. It will run smooth than rough, maybe smooth again and quit. I slightly changed the point gap. (I hope I did not messes up the timing).
Anyway I would appreciate any suggestions you all can give me. Thanks.
PS What do you suggest for spark plugs? (ie my Lark is a 6 six cylinder). I have used Champion 857 (rh16y) and Autolite 226 (If memory serves me) The Champion works ok, but is getting hard to find, and Autolite does not last).
