I have a 1961 Hawk the following is my experience. I may be wrong. Brakes are NO JOKE!
The Shop Manual instructs that the brake pedal be separated from the actuator rod at the front end of the Master Cylinder and the "lines" disconnected from the back end of the Master Cylinder. I simply loosened the mounting bolts: Disconnected the "Y" and slid the Master Cylinder off the actuator rod. Thus when reassembling there was no need to deal with free pedal play, clevis pin reassembly or anything on the front end. As far as the back end, the brake lines stayed attached to the "Y" so assembly was easy. Why did the Shop Manual say that stuff I have no idea.
