I'm currently working on a 1953 studebaker champion with a 3 speed T96 with overdrive. I was adjusting the clutch linkage to allow for proper freeplay when i realized that something wasn't right. For some reason, with the turnbuckles wound all the way in, there was still an excessive amount of freeplay (approximately 4" at the pedal if not more).The car had been sitting a while and suffered from what is apparently a common problem of the clutch disk attaching itself to the flywheel. We removed the transmission and dealt with the frozen clutch disk. While apart i checked the throw out bearing along with the two arms that activate it and everything looked great. According to the manuals, i have the proper linkage for the wheelbase. My question is; would the clutch disk being frozen to the flywheel cause the excessive freeplay? or is there possibly something else involved? I want to avoid re-installing the transmission only to find that the problem is not taken care of. Any help would be great.
Thank you
Thank you
