Will the timing gear cover from a 232 fit a 1957 259 engine?
232 timing gear cover/1957 259, will it fit?
I think it will work better this way than the reverse. I put a later timing cover on my '51 232. I merely blanked off the fuel pump opening. The problem with the later aluminum timing covers with the fuel pump profile, is that the original 232 water manifold will not fit with the later timing cover in place. Therefore, I had to change the water pump manifold. I went to the later timing cover with the improved modified chevron seal that I bought from Lionel Stone. I don't know if anyone converts the early timing covers to this type of seal, but it sure helped my car leak less oil.John Clary
That looks like it should work, the only issue I see is that Left Hand side choke would require a '51 Exhaust Manifold with the Left side Choke Heater unless you change the Intake and Carb. to a '55 to 57.StudeRich
Since you are installing a 259 in "stealth" mode...I have a question and perhaps a possible idea to further its appearance as a 232. My question is...how small are the electric fuel pumps? In all my years of tinkering with these old cars, I have zero experience with the inline after-market electric fuel pumps. However, I was wondering if they are small enough to fit inside a gutted mechanical pump. If so, it would be a cool trick to fit an electric pump inside the housing of one of the mechanical pumps and install it on the oil filler tube to look like an original pump. Aside from some creative plumbing for the fuel line, the electrical wiring would require some special routing to not draw attention to it. That would be a pretty good challenge for someone who enjoys tinkering the way I do.
Of course, if this does not work, you could still gut the mechanical pump, put an internal tube from the inlet to outlet so that gas would merely pass through it, and hide the electric pump in a safe place under the car along the chassis. At local cruise-ins, aside from seeing the V8 in my Land Cruiser (most non-Studebaker folks seem to think that all bullet nose Studebakers came with only flat-head six engines.) the fuel pump on the top of the engine mounted on the oil filler gets lots of comments.John Clary
