The speedo stopped working in less than 100 miles, in the GT with the recent 700R install. When I disconnected the cable at the tranny to see why it had stopped turning, I discovered the square end of the cable fit very sloppily in the square hole in the end of the plastic pinion. I figured it had somehow wallowed out, so ordered another pinion. When it arrived I compared the new pinion's square hole to the end of the cable, and to the end of a spare Stude cable. Turns out the end of the Stude cable and the one that came with the kit is .104" square, and the hole in the pinion is .150" square. So it appeared there was another learning curve to climb.
I then did some reading on speedo cable core/end sizes, and discovered there are three, and each is used for different applications: The .104" is for passenger cars, light trucks and vans; the .150" is for heavier trucks and vans, and a .187" is for big rigs. I then double checked several 700R pinion catalogs' listings, and found no reference to square hole size, only to number of teeth.
Looking closer at the square hole in the pinion, I discovered it is 1 & 3/8" deep, and the first 1/2" is .150" square; afterward, it quickly tapers to .104" for the remaining 3/4" or so. So, it appears this was GM's way of making the same pinion fit both the .104" & .150" applications.
My problem is, the cable I bought only sinks the tip of the cable about 3/4" into the pinion. Looks like the fix is gonna be to install a universal core, and cut it about 3/4" longer so it will bottom out in the pinion.
Has anyone else ever encountered this ?
Thanks,
Thanks,
