I am rebuilding the split bench front seats on my 62 Lark and when I took the backs off, a ball bearing fell out of a worn retainer. The ball bearing is spring-loded in a retainer that goes into a 3/8" dia hole in the hinge part of the seat frame. The one on the other side was missing altogether. I found the item in the SI catalog (Part # 1355869) but just got a call from them saying it is out of stock and will not be available. I assume someone got the last NOS ones before me. It allows smooth movement of the seat back and gently locks the seat back into place.
I did an internet search looking for something like it but have drawn a blank. Anyone else have this same problem and if so what did you use as a substitute? I was thinking maybe I could fit a nylon glide in there that will allow smooth movement but obviously it wont lock it in place. Any help or thoughts will be appreciated. Thanks.
