1959 Lark VIII Regal Rear end questions!
  • Rear Axle: 1959 Lark VIII Regal Rear end questions!
    OK guys and Gals You seem to be very knowledgeable about the secifications of Studebaker Cars and Trucks so here are My questions.
    1. Did Larks in 1959 Have a form of POSI TRACTION? As You know I have a couple Lark regal VIII's , a 2 DR. Wagon and also a 4DR. sedan. The wagon has 3spd on the tree with overdrive and the 4Dr. has an automatic. I was just wondering if there is a special # or tag at the rear end housing that I might find the information that I seek. 2.Also just wondering if the rear ends are worth the effort to install into My 1951 2Dr. Commander State Starlight Coupe. As always Your input is appreciated.
    Patrick Sammon
    Studebaker first had Twin Traction (like a GM Positraction) available on pickups in 1956 and on cars in 1957. So, yes, a 1959 may have TT. One easy way to tell is to take the plug out of the differential and try to stick a finger in the hole. If it almost immediately hits something, you have TT.
      I wonderd what the TT in the Circle ment? I'm pretty sure the wagon is Twin Traction as the TT chrome piece if from the 59 Lark regal 2dr wagon. But will it (The rear end fit My 51 Commander Starlight, without shortening it? Comments appreciated!
      Patrick Sammon
        51-52 rear ends are shorter/narrower than 53 and newer.
          My mechanic took a good hard look at the Commander rear end ( and says it should be just fine as The 51 Commander already had a V8 Stock from the factory), and since the car only has 54000 original We will just change the fluid and seals and give it a go. Thanks for Your replies all!
          Patrick Sammon
            The other way to tell is if the tags & decal are missing is turning the rear wheels while they are off the ground. If you turn one side & the other side turns the same way its a twin traction rear. If the other side turns the opposite way, then its a standard "open" rear.
            60 Lark convertible V-8 auto
            61 Champ 1/2 ton 4 speed
            62 Champ 3/4 ton auto
            63 G.T. Hawk R-2,4 speed
            63 Avanti (2) R-1 auto
            64 Zip Van
            66 Cruiser V-8 auto
              Yes.
              My 59, 259, auto trans., Lark, 2dr. wagon has a Dana positraction unit, along with 3.55 gears.
              While it is worn out...it is there. It needs friction plates.
              P.s. - like in my case...turning the tires is NOT a definate way to verify a posi unit. The only way to positivly tell...is by removing the cover.
                When you change the fluid in a TT differential, add a small can of limited slip fluid, such as used for Positraction by GM.
                  Did your mechanic's "hard look" include measuring the track width of the two and the "nose" length?
                    I took it to mean that the mechanic said the differential that was already in the 51 was fine, being that it is already a Dana 44.
                    Maybe Patrick can clarify this.
                    A key question is; what is the ratio, or what type of transmission was in the car originally and what type will be going into it. You want the proper axle ratios to go with the engine/transmission combination.
                      Yes Roy it is a Dana 44 and the internals are very clean with no visible wear, also the brakes look brand new. I'll try to get some pics this week and post them Thanks all!
                      Patrick Sammon
