View Full Version : Stromberg model WW
Scott
09-24-2006, 05:19 PM
I was going through boxes looking for an old solid state radio when I came across a box of old Studebaker parts I barely remember getting. In the box, among a few hawk parts was a nice clean Stromberg WW carburetor with some of the linkage still attached. I never found the radio (of course), but I'm wondering what a WW carb is for. Anyone know?
I also found a couple parts I had to figure out what they were. They are support brackets for the air cleaner on a 1957 hawk with the flathead engine. I think I had two made up by a machine shop because I couldn't find a real one.
ROADRACELARK
09-24-2006, 06:20 PM
Scott,
To be more precise as to what that "WW" fits, find the small #s on the top cover of the carb that covers the float bowl..should be 6-***. In the parts books that # will tell you what year car that fits.:)
Dan Miller
Scott
09-24-2006, 06:39 PM
I checked the carburetor and the number on the top is 6-132. The 2 is worn a bit, but I'm pretty sure it's a 2. I don't have a parts book, but maybe someone online can tell me what year that would be for. I'm pretty sure that it uses an oil bath air cleaner, but I don't have that.
ROADRACELARK
09-24-2006, 07:00 PM
Scott,
According to the info I have, that fits a 63' or 64' car or truck. :)
Hope this helps.
Dan
Scott
09-24-2006, 07:13 PM
I wonder if that's the unit I took off a 1964 sedan that was abandoned near where I lived when I was in my teens. It could be the same unit. I've wondered for years where it was.
No, wait a minute...That must be the one I took off my 1964 Daytona when I switched it to a 4 barrel (WCFB). I've also been wondering where I put THAT one! [:I]
I suppose a good core isn't worth too much.
Thanks!
ROADRACELARK
09-24-2006, 07:42 PM
If the throttle arm is still attached securely to the shaft and all of the pieces, linkages, choke system is all still intact, you'd be supprized. I bought a good one from Robert (Transtar56), a few months back for $30, put a kit in it, works as good as new. You want to sell it[?] leme' know.
Dan
09-25-2006, 01:03 PM
I've got a shelf full of core WWs. They were used on Studes from 53 thru 64 as well as many other makes of cars over time. Lots of them were used on industrial engines as well.
They're a good-working, durable unit. Only the throttle shafts tend to go south on them. More precisely, the throttle shaft bores. Shaft bores rebushed and carb rekitted - good for another 30 years!:D
Miscreant adrift in
the BerStuda Triangle!!
Scott
09-25-2006, 01:21 PM
Hmmm. I've got a core and I sold the Daytona. So THAT means I'll have to buy another Studebaker to put this on, right? [:p] Well, maybe an engine at least, THEN the rest of the car...
09-25-2006, 01:45 PM
Aha! The light bulb's coming on Scott! Why do you think I have ten thousand Studebaker parts lying around???
"Honey, I've got this here dash cluster from a '53 coupe. Isn't it only logical that I bring home a car for it to complete???"[:p]
Miscreant adrift in
