I've often wondered about the longevity of the Studebaker V8. In the early 80s I purchased a '62 GT from the widow of the original owner, who by the way had been killed in an accident while driving another Studebaker. At the time of purchase the car had 195,000 miles on it. With the car was a logbook giving every bit of maintenance and gas purchases since new. The only evidence of engine work was the rear seal being replaced several times. We used the car as a regular driver for a couple of years, but at 210,000 mile decided it was time. The car was still running fine and didn't smoke, but the oil pressure was only about 25-30 pounds when running on the highway. Even though the crank looked near perfect I had it ground .010. The cylinders had some wear, but only needed .030 pistons and there may have been a couple of exhaust valves needing replacing. We drove the car another 40-50 thousand miles before selling it.
I should add the original owner was an engineer and the car was well maintained. It was purchased with a 4 speed, but he wasn't satisfied with the gas mileage so swapped it for an overdrive. Subsequently his average mileage jumped from 17-18 up to 21-22 mpg. It only had a 2 barrel and the 3.31 gearing left something to be desired in performance, but it was good road machine. I think the engine turned about 1800 rpm at 60 with the overdrive engaged.
So, I was wondering what others have experienced in the way of longevity for this engine? I will add that the other 4 or 5 engines I have torn down with fewer miles generally had more wear.
