I see that SI wants $750 for a new t96 overdrive. Whats a fair price for a used t96 overdrive from a 58 sliver hawk flat head 6 with 30,000 actual miles on it? Anyone need one?
t96 overdrive trans
Tags: None
at 1st I thought you wanted to buy one.....but the answer is still the same. Mileage should mean nothing to the buyer unless he drives the car (tranny) before buying it. That being said, like most engines...its a " pig in the poke".....I'll throw out a $150 amount to get things going. Also...having made this mistake myself, the '59 and up trannys do not work with the earlier trannys ! they have different speedo gear/input sizes.......so you'll be selling your tranny to a pre '59 owner.
I suspect there are quite a few folks driving those flatheads with a straight 3-speed who would love to have overdrive but simply haven't given it much thought. They are also heavy to ship.
So...you are looking at a limited market that YOU will need to hunt for or create; and they would prefer you be able to deliver it to a swap meet or other convenient locale.Brad Johnson,
'56 Sky Hawk in process
Unless you are very lucky - it only takes one- $100. Demand, location, shipping all enter into this.
I sold a good OD transmission for a late V8 for $150 and that included new cable, wiring, etc.Gary L.
I know this was a good trans when I pulled it out in the mid 80's. I drove the car for a few months and it had 29,000 and some change actual miles on it. It was a stock flat head 6 and ran good but smoked a little and leaked oil from every gasket it had as it had sat in a garage in north Minneapolis for years. But a clean of the gas line and it fired right up and you couldn't hear it run. I just thought maybe some one with a mid 50's 6cyl and three speed may want overdrive.
Originally posted by swvalcon View PostI just thought maybe some one with a mid 50's 6cyl and three speed may want overdrive.Brad Johnson,
Originally posted by jackb View Postat most engines...its a " pig in the poke".....I'll throw out a $150 amount to get things going. Also...having made this mistake myself, the '59 and up trannys do not work with the earlier trannys ! they have different speedo gear/input sizes.......so you'll be selling your tranny to a pre '59 owner.
Originally posted by swvalcon View Post/Cut/I just thought maybe some one with a mid 50's 6cyl and three speed may want overdrive.
The issue no one has mentioned is that a '58 is a LONG TAIL Trans.
So it does not bolt into a '57 or older car without changing the driveshaft type, and cutting out the crossmember.
If it is true that '59 and up speedo gears are different as noted in Post #2, that would make it '58 only, but I doubt that. The big change was '58, and after that should be all the same.StudeRich
