Are the aluminum side moldings on a 1964 Wagonaire Daytona always painted black in the center section. Seems like I have saw pics of some with white. Are some not painted at all ? The ones I have for my car do not show any signs of ever having any paint, so I am not sure how they should be.
Wagonaire side trim
Originally posted by BobPalma View PostThe raised portion of the center section of 1964 Daytona side trim is painted black.
It quite often falls or wears off or gets bleached out, but it was black to begin with. BPPaul Johnson, Wild and Wonderful West Virginia.
I repainted my '64 Daytona trim using a satin black. I think it looks fresh. Besides it softens (flattens) over time. My buddy Patrick posted pics earlier this year- just search '64 Daytona wagon and you should see it. Rob in PA.
Ok , Thank's for the info guys. Now more stuff to paint, I may use semi gloss single stage urethane, it will be more uv resistant and I will be using it on some other parts too. None of the trim I have shows any signs of ever being painted even on the ends where it overlaps, but to make it look right I guess I will paint them.
That is correct; just the surface, not the edges of the raised part are Low Gloss Black.
IF the Door and Front Fender Mouldings have any Paint at all in the upper and lower grooves, that indicates they were FOR or FROM a '64 or '65 Cruiser, or a '65 Wagonaire, and the Rear Quarter ones could have been bought for a '65 Wagonaire.StudeRich
Originally posted by StudeRich View PostThat is correct; just the surface, not the edges of the raised part are Low Gloss Black.
