Background.. A hotrod Ford running a 55 259 w 55? 3pd truck trans. It has the top shifter plate. Taking off in first you have to let the clutch out real quick or it will chatter like hell. If you don't try to slip the clutch it's fine. I can prevent it most of the time.
I've dialed in the new bell housing to the crank which I've learned here could cause this problem. Depending on the obvious visible condition of the pressure plate and flywheel, I am considering reusing the pressure plate. If necessary the flywheel will get surfaced and a new disc to fit the 5 spd. trans.
Is the Stude prone to clutch chatter? (Fords had anti-chatter rods from the factory) Is the pressure plate a likely suspect? Weak or broken springs on one part? I'll give it a good once over.
I don't like doing things twice but I also don't like spending money to replace a perfectly good part that will probably out live me.
This is the first vehicle I've had that chattered. I'm really hoping the new stuff installed correctly will eliminate the very embarrassing problem.
I know the present engine and bell housing didn't come from the factory together and I'm suspecting that whoever put it together was a Chevrolet mech. and didn't know to dial it in.
What should I be looking for?
