Had a chance to put a charger on the 63 today to crank it over, but didn't try to start it due to old fuel in tank. Removing the tank is on the to do list so it can be properly cleaned. I really want to hear it run, and would like to get input on a way to bypass the rear tank to get it started. Itching to hear it actually run. One friend told me to attach a hose to the fuel pump and put other end in gas can strapped to firewall. Prime carb, and start. Logical or not????? Thought I would ask Stude guys, and gals before doing this.
Cranked the Lark today !!!!:)
that's fine, but if you haven't changed the old oil out - depending on how long she's been sitting - i'd want to do that.
for moving her, don't do anything until the brakes have been gone thru. also tranny fluid especially if an automatic...
lots of stuff can be found on links here: http://www.studebakerdriversclub.com/tips.aspKerry. SDC Member #A012596W. ENCSDC member.
My wife is a nurse. She taught me how to hang an IV. I even have an old IV pole discarded from the hospital. I have a metal cylinder,tapped at the bottom and open at the top. Hang the canister on the pole with wire. run a hose from the bottom tap to the carb. Fill canister with fuel. with the pole higher than the carb, the fuel will gravity feed in to the carb.Neil Thornton
Instead of pulling the tank, why not just siphon out the old gas, put in some new gas and be done with it?
I know that everyone wants to pull and clean the tank, but I have never done that and, coincidently, have never had a gas tank problem. Maybe it's the climate here in California, maybe something else. But unless the tank has holes in it, why bother?RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by RadioRoy View PostInstead of pulling the tank, why not just siphon out the old gas, put in some new gas and be done with it?
I have used outboard motor 6 gal gas tanks over the years to start cars that I have not wanted or been able to use the original gas tank. I just connect it to the fuel pump inlet or the carb inlet(providing the gas tank is kept above carb level) and you are ready to go. You can use the squeeze priming bulb on the line to prime the the carb. They used to make them in 18 gallon capacities and a friend of mines dad installed 6 of them in his pickup that he used for hauling a 5th. wheel trailer in the late 70's.
Well...I have never skinned a cat. However, I have heard there's many ways to do it. Same with installing a temporary gas supply to run an engine. I have an improvised engine test stand. For it, I am using a small re-purposed plastic mower tank. The tank is mounted high enough so that gas gravity feeds to the carb without a pump. I have also installed a small inline shutoff valve and one of those clear plastic filters. Not (so much) to use as a filter...but when if the engine shuts down or stalls...it's easy to see if it is empty and thus, the tank has run out of gas.
I have used this method many times to run an engine, in a vehicle, when I suspected the tank could be contaminated. The above post regarding an outboard motor tank is also OK. However, even the smallest of those tanks hold more fuel than I prefer for temporary running. The one on my engine stand holds about a half gallon.John Clary
Hmm, why do we need to clean out the tank, instead of just putting fresh gas in it, and calling it done.....well, for me this is why, but for all I know, I'm just making extra busywork for myself. I do know that engines don't do real well when they digest this type of "fuel", so might as well get it all out and start anew!!
Every Studebaker that I pick up that's been sitting for many many years, has the same thing done to it. Old fuel comes out, tank gets flushed, new lines and hoses are put in, the whole works. In all actuality, this tank on my '63 Daytona was coming out anyway. I have a much, much better one in the '64 Commander. The car had been sitting for quite some time, like in this case, for many years! I dropped the tank, and shook it around. It felt like somebody had stuffed some sod inside of the tank, because it sure felt solid. So, I flipped it over, and shook out whatever it was that was in the tank. What came out looked like brown dirt, rust, and clay, and smelled like old varnish. I still haven't gotten it all out either, because there's some real large clumps in there that won't come through the fill hole. Now, a few of us could probably either try and flush it out, or put in new gas, and get the engine to run(this car doesn't have an engine or trans), and call it day. But whatever trip it's taken on is gonna be very short, because this will immediately plug up the lines, filter, or anything in between the tank and carburetor!1964 Studebaker Commander R2 clone
