Need help here. Every time I step on the gas pedal I get a hesitation or flat spot where it sounds like it is going to stall out. No power and it bogs out. This only happens at very slow speed. When I double pump the pedal it is fine and I get great pick up. It runs fine at speed.
'57 Transtar 1/2 ton with 259 bored out to 289. New rebuild, 2 barrel carb rebuilt, distributor rebuilt, timing set correctly with Pertronics unit. Has a manual choke cable set-up that I use when starting cold.
Any ideas as to what is causing this and any recommended fixes?
