View Full Version : Question on 63 Super Lark
00RACER
01-10-2014, 10:39 AM
On the 63 Super Lark, they had a large fan shroud. When they used that large fan shroud, did they still install the small shroud on the radiator at the top?
THANKS
PAUL
01-10-2014, 01:12 PM
It is extremely rare for any Lark to have the optional Fan Shroud, it was sometimes on A/C Cars, Police Cars or JT Cars, but I do not believe it was Standard on anything.
So it may take a while to find someone who has actually seen a Factory installed one to answer this, I do not remember if they had the "Hands shield" or not, sorry.
SScopelli
01-10-2014, 01:20 PM
I removed my hand shield.
I wish I had not..
http://i1286.photobucket.com/albums/a609/R2Whistler/R1%20Lark/DSCF4484_zps1d24ddbc.jpg
2R2
01-10-2014, 01:33 PM
Paul, as you can see in the attached link from Popular Science, the car tested does not have a full shroud:
http://www.curbsideclassic.com/automotive-histories/automotive-history-1963-days-popular-science-tests-the-hot-compacts/
This is a early car, as it also has the Avanit 160 speedo, before the Lark 160 was introduced. Also note it has a 3:54 axle. Back to the shrouds - I installed one one mine, but left off the hand shield. As Rich stated, the shrouds are not seen that often, and when I have seen them, there has not been a hand shield (never knew what that thing was called!)
8E45E
01-10-2014, 02:19 PM
Here is a '64: http://forum.studebakerdriversclub.com/showthread.php?30201-From-the-Archives-14-(R-4)&highlight=shroud
00RACER
01-10-2014, 04:04 PM
that pic from the richard quinn collection is identical to what i have. The part number is real nice on the top of the schroud. The radiator is an air conditioned car radiator with the mount on the top with two holes to mount the hand shield, and i was curious to see if they used the holes. Thanks for the response
paul
Colgate Studebaker
01-12-2014, 02:56 PM
Try getting in touch with Jim Pepper. He has a 63 Super Lark that he has owned for eternity, and he can probably get you the correct info you need. Bill
SN-60
01-12-2014, 03:42 PM
A stock '63 Super Lark could only be an R1 or an R2...so only the small 'fingers protector' would be used.
00RACER
01-12-2014, 04:32 PM
NO, that is incorrect because the 63 Lark this complete shroud came out of it was on from new, and it was an R1. I am sure the one on the richard quinn pic is correct
THANKS
8E45E
01-12-2014, 04:51 PM
Here is the Ebay 'desert car' '63 that was up for auction a few years ago. I did save the photos of the engine with the unusual shroud.
http://farm6.staticflickr.com/5529/11915389745_44e347514d_o.jpg
http://farm8.staticflickr.com/7363/11915389925_28f2398534_o.jpg
SN-60
01-12-2014, 04:55 PM
THANKS
Well I guess it's possible that R1's may have had this full shroud whereas an R2 would not have it due to the extra clearance needed for the supercharger. I guess it's time to open the parts/chassis manual!
2R2
01-13-2014, 02:00 PM
Paul, as I mentioned, I have a fan shroud on my factory '63 R2 Lark. One thing to keep in mind is if you install the shroud, it is just about impossible to get the blower belt off! The blower belt is to fat and rigid to snake off the pulley, as it is to close to the blower. In fact, if I need to chage the bets, I prop up the radiator, take the four bolts off that hold the shroud and radiator, and push the shroud back over the water pump in order to access the belts.
31346
SScopelli
01-17-2014, 10:12 AM
31346
Very nice picture. So the finger guard is only the portion on the radiator and the extension is not put on..
Nice engine, but why the bungee strap across the air cleaner hose?
2R2
01-17-2014, 01:37 PM
You know, I can't remember why that bungee cord is sitting there! I must have been using it to hold something back while I was working on it...it certainly is not there now!
31461
