Well I'm replacing the heater hoses on the '58 Commander the wife n I recently purchased. And the lower rad hose and t-stat too. Decided to check the core plugs and found a very small weep from the center one on the driver side. Stabbed all of them with a screw driver and they all passed the test. Still....... being OCD I decided now was the time to replace them all. Popped all 6 out after getting 6 new ones in hand. I've been back reading alot of topics posted here for information and I got to tell you like so many here said........... There is alot of crud inside that block. All 6 plugs were completley covered.
You couldnt tell I had removed them. Six wall's of mud I stabbed through and then came some fluid. I fashioned a tool from a steel banding strap to get in there and freeup the muck. Stab stab stab, garden hose til it's clean. Stab stab scrape scrape garden hose. For 1 hour I was at it. Poor engine has a cooling coronary goin on. That motor should be one cool cat when its all sealed up again.
That is some of the nastiest stuff I have ever seen come froma block. I'm putting convex core plugs back in and the block surface is in great shape where they seat. Still gonna run a small bead of sealant along the plugs for peace of mind. to all of you that have done this "KUDOS" that Is one nasty job. Todd
(Just got done going through the warm up til the thermostat opened. No leaks and no core plugs shooting out of the block. Both heater cores nice and dry. The hoses to the main core were original. They still had undercoating on them. I cut one open and it was so soft and started falling apart internally. Now I wont have a burst hose scenario running through my head when I drive her. That was always bothering me. Temp gauge sits right in the middle. Think it's time to stop typing and go driving.....WOO HOO!!!!!!!! Thanks for all the pointers guys. Made life a lil easier. Todd
