I was wondering what other car's/truck's wheels fit a 63 Lark. Would like to eventually find some aluminum wheels foe a 63 four door Lark that is being delivered this coming Saturday.
What wheels fit a 63 Lark?
Here's some data that should help:
The Studebaker bolt pattern is the same as the standard 5-on-4.5" pattern used by Ford, MoPar and AMC, and many of these wheels will fit. Stock 5" Stude wheels have a 4.25" backspace, and OEM Ford & Mopar wheels with 4" backspace work just fine on a Stude.
Lots of Lincoln and Crown Vic wheels from 1990 - 1997 come 15" x 6 1/2" wide with dead on back spacing, as well as 15" x 6" wheels with a 4" back space found on Ford LTDs, Mercury Marquis or Crown Vics from 85-89.
Chrysler 15x7 M-body (Dodge Diplomat, Chrysler New Yorker) wheels will work as well; basically any RWD Chrysler Fifth Avenue or variant from Dodge or Plymouth (like the Diplomat, Fury, even Imperials).
For my car, I went to the junkyard and pulled a wheel off an '80s Diplomat for test fit, then bought brand-new Wheel Vintiques 15" x 6" Chrysler original-equipment style repros. They come in satin black, which was perfect for my car, and I finished them with Dodge vented police hubcaps on the suggestion of StudeRich The Studebaker full-disc wheel covers will fit any of the above mentioned wheels, but the dog-dish caps will not hold, so be aware of that.
Good luck!
Clark what size tires are you running on these? I'm wanting to use something like this and run 215/75/15's with the original wheel covers on my 1964 Cruiser.
Thanks,
Joe
Good luck!
[ATTACH=CONFIG]31103[/ATTACH][ATTACH=CONFIG]31104[/ATTACH][ATTACH=CONFIG]31105[/ATTACH]sigpic
1962 Daytona
1964 Cruiser
And a few others
All mine 15 x 4 1/2 bolt pattern when measured from rear side of wheel flange to end of wheel 4.25 1963. Drum brake car cheers jimmijimOriginally posted by 11SecAvanti View PostAre you sure the back spacing on a stude rim is 4.25"????sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
SBK,
Those drilled Cop Car hub caps are worth a bundle of bucks. I have seen a pristine set of four going for $300! Even a fair condition set with the slotted steel Cop Car wheels go in the $300 for wheels and caps combined. Being a CAMO (similar to CASO) I've picked up rather dented drilled caps in the $5-$10 range and "plinked" them into decent fifteen footers.
eddienlinda,
I have the Crown Vic Cop Car wheels on my '64 Lark. 225-60-16" are kind of wide (but the spec size on the CV).
Originally posted by 11SecAvanti View PostSo a 4.500" inner rim width wheel has a 4.250" backspace. Can you host a picture of this measurement?
Note that "width" is measured INSIDE the bead and backspacing is measured OUTSIDE the bead.Dick Steinkamp
Bellingham, WA
Originally posted by showbizkid View Postbought brand-new Wheel Vintiques 15" x 6" Chrysler original-equipment style repros. They come in satin black, which was perfect for my car,RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Roy, it's this wheel:
Side note: apparently AMC 15" wheels work since they also have that 'odd' size Stude hub cap mtg design.--------------------------------------
