I have a hawk six automatic. It runs good, 125 compression, no smoke no noises, and has about 30k miles on a "near major overhaul". However, oil pressure is less then desired at hot idle. At hot idle I have about 5 psi, with 15-40 oil and one can of STP. Driving while hot I have about 20-25 lbs. Cold I have 40-60 and when hot, the oil gauge could be used as a tachometer!
I suspect that when the engine was overhauled, the lifters were overlooked, since everything else is okay on the engine.
Anyways, I was adding up the cost to rebuild the flathead six and it's shocking! I'd have to have most the machining done at northwestern auto in Grand Rapids, 100 miles from me as nobody want's to get involved in a flathead locally. All the prior flatheads I rebuilt I got away without too much machining. I'd have about $1000-$1500 in doing the engine well....which got me to thinking....
I have a couple nice 289 or 259 automatic combos that I could put in (and I have several 60-61 V8hawk rot bucket parts cars), but I'm not sure it's worth it, especially on a hawk six.
If this was your car what would you do?
A) would you modify the car and have a mutt with a 259/289 in it?
B) or would you stay with the flathead six?
C)Or would you sell it and go buy a V8 hawk and pass on the I guess sorta scarce flight hawk to somebody else?
BTW, does anyone have a NOS 185 shortblock around? I'd sure in the hell could use one.
