There's more! Not being as familiar with the 4-Jet as with the WCFB and the AFB, both of which I have rebuilt (many times), because of some hesitation when starting from cold, and stopping as if not getting enough gas, I decided to take the air horn (bowl cover) off the 4-Jet, but neglected to remove the one bolt inside the air horn. Thinking someone had previously sealed the gasket with Permatex, I spent a long time prying the cover off, only to break one of the tabs extending into the bowl. Oh shuck, I thought, actually something more odiferous! Went down to O'Reilly's and bought some "JB Weld", strongest strength, and repaired my error. I will let it "cure" for several days, and hopefully seal (no supercharger here) and hopefully, the "weld" will not be dissolved by gas or ethanol after I re-assemble it with a new accelerator pump, gasket, and pump boot. I thought there was no reason to mess with the float settings or jets, since it ran fine otherwise---except as mentioned. It would even stall after warmed up if I used a heavy foot on the accelerator, thinking that this was not a choke problem, but one of a worn accelerator pump. I have attached a photo of the repair so far.
Maybe someone can tell me why the photo I uploaded from my wife's Mini IPad is always uploaded inverted. I tried reverting it in using her IPad, downloaded it to my laptop, rotated it 180 degrees in the laptop, saved it, and uploaded the image again, but it was always inverted when it appeared in the forum download manager and as above. Suggestion: Turn your laptop upside down to see image 2, or stand on your head on your chair if you are looking at a desktop monitor.I guess I have too much time on my hands editing these posts But look what happens when I start working on the cars!
