The 63 289 Stromberg 2-bbl was on the engine/car when purchased nine years ago. Do not recall any particular issues at that time (but, there were many other prob's that were present) A couple years later the 2-bbl was replaced w/ a Carter four bbl and after solving several problems ran very well. The four bbl has been now removed to a replacement engine and the Stromberg re-installed - Since then the following situation has occurred:
The car surges/bucks at low speed and light throttle (30-45 mph). It idles fine, accelerates fine and runs very well at higher speeds (50mph plus).
The carb has be disassembled (including main jets and tubes), cleaned w/ carb cleaner (on the third can of spray) and blown out w/ air - This is the third time it has gone thru' this process - No change in performance.
Any suggestions as to what I am missing?
Paul TK
Paul TK
