what front shocks would be good for a 54 pick up with a 259?
front shocks
Tags: None
The stock OEM replacement Gabriel Gas Shocks or Monroe for 1/2 Ton Trucks are the same for all Engines.
When you are logged in and click on your Duplicate post you can hit the "Delete" button at the bottom.Last edited by StudeRich; 12-12-2013, 10:54 AM.StudeRich
While you're under there, check the spring eye bushings on both ends of the spring. The Studebaker design there is just bad science, having the shackle bolt wearing directly against the soft rubber. The bushings "perish" after only a couple of years of driving. Fortunately, they're cheap and easy to replace, because they need replacing often.
jack vinesPackardV8
