I replace my Distributor and I seem to have an extra wire, there is one wire coming from the coil to the outside terminal of the distributor and there is a red wire I think was attach to the same terminal outside the distributor, can anyone help me solve this, thanks Earl
53 Champion, distributor wires on outside
A little more info would sure help. Is this an Overdrive Car?
There should be a small 16 or 18 ga. wire from the Coil (+) Terminal to the Dist.
IF it is still running a 6 Volt Positive Ground Battery.
If you look closely with a flashlight there is a small (+) and (-) mark on the Coil.
With Overdrive, there would be another ground wire from the Overdrive Kick down Switch to the side of the Dist.StudeRich
Originally posted by earles1985@aol.com View PostYes it has overdrive, now dose that wire connect to the distributor side of the coil at the distributor terminal
