View Full Version : Anyone know a good trick for this?
afgarcia86
12-11-2013, 01:25 PM
I need to send my sun visors to Southeast Studebaker. However the plastic pins that were in here snapped. Does anyone happen to know a good way to get the rest of the old pin out?
30376
2R5
12-11-2013, 01:33 PM
Probably the easiest way would be to dill as many as possible small holes in it than break it apart.
afgarcia86
12-11-2013, 01:35 PM
Not sure why I didn't thank of that. I will give it a try thanks.
gordr
12-11-2013, 01:36 PM
I think the last time I had to deal with that, I carefully spread the metal tube with a screwdriver, and slipped the broken piece out.
Another suggestion: drill a 3/16" hole in the plastic piece. It will drill easily. Find a wood screw that would be a tight fit in a 3/16 hole, heat it up with a torch (not red hot), and screw it into the hole you drilled. Allow it to cool, and pull it out with the screw? I know I never went to that much trouble.
You could just drill it right out, too. Ever larger drills, until one hits metal on one side. At that point, the remaining shell should about fall out.
M15 Trucker
12-11-2013, 03:29 PM
i need to send my sun visors to southeast studebaker. However the plastic pins that were in here snapped. Does anyone happen to know a good way to get the rest of the old pin out?
30376
get a pair or three of these in different sizes. They are called hemostats and can be found some gun shows were vendor is selling used tools. You can easly grab the broken end of the plastic nob and pull it out, i did the same thing with my visors.
30381
rockne10
12-11-2013, 10:17 PM
They are called hemostats That's not what we called them back in the sixties! :woot:
afgarcia86
12-11-2013, 10:19 PM
The drill technique worked like a charm.
