By the shift linkage on the steering column?
The one dead center in the photo is the backup lamp switch. Factory? I don't know. There are 4 wires on the kickdown switch. The two black ones are hard to see.Gord Richmond, within Weasel range of the Alberta Badlands
There were a lot of J.C. Whitney-type aftermarket backup light kits out there. My car has one installed but the wires are shredded so I removed the switch. Definitely not factory. I might re-purpose the lights as LED brake/turn signals if I get ambitious. I don't need backup lights. "What is behind me is of no concern"
You can sort of see the switch clamped to the column with a band clamp. Click HERE for a bigger version:
And here are the lights in the back of the car:
My thoughts are that if it is a functional switch...make sure it is wired with appropriate wire size and protected with a fuse rated for the job, and use it. I have two Studebakers that were not equipped with the "option" of back-up lights. I rarely drive them after dark. Having the lights would be a plus. One of mine originally only came with a single tail light and had no turn signals...certainly not a back-up light. I have since added a second tail light and turn signals. Just have not gotten around to the back-up light... yet.John Clary
Backup lights not only help you to see while backing, they alert other motorists to the fact that you are backing. Very useful when you are trying to back out of parking place between two minivans, and are essentially blind to cross-traffic in the aisle of the parking lot.
On my old '85 Suburban, I had a pair of small halogen fog lamps mounted behind cutouts in the rear bumper, connected to the backup lamp circuit. Very useful when I hit a dead end on some bush trail, with no room to turn around.Gord Richmond, within Weasel range of the Alberta Badlands
I think it's a Studebaker part. The wiring for it won't be in the main diagram, but should be shown in accessory diagrams. Or you could order a copy of the installation instructions here: http://www.studebakerdriversclub.com...rtemplates.htm
522966: Switch, back up lamp 6G THRU 12G 14A THRU 3HRestorations by Skip Towne
You may also want to note that your circuit may be a bit more complicated than you expect, because Studebaker Back-up Lights before somewhere around '59-'61 were wired THROUGH the Ign. Sw. AND the Headlight/Parking Lt. Switch, so you need BOTH ON, and in reverse, to operate the Lights.StudeRich
Originally posted by StudeRich View PostYou may also want to note that your circuit may be a bit more complicated than you expect, because Studebaker Back-up Lights before somewhere around '59-'61 were wired THROUGH the Ign. Sw. AND the Headlight/Parking Lt. Switch, so you need BOTH ON, and in reverse, to operate the Lights.
I can't thank you guys enough....well I could, but then I'd be broke. I've heard mention many times about parking in reverse for safety sakes, which if the switch was wired direct would leave the light on all the time. There is no problem for me fusing the light and the little back up switch does work. And you are right, the circuitry is a whole lot more complicated than I intended. But, it appears to be easier with a plan in place to isolate the parts as individual pieces( write em down and check em off) and use the OHM meter to wire each part according to the wiring diagram. Thank you
