View Full Version : 1950 Champion door shims and carrier bearing grease gasket needed....
bosshoss61
12-10-2013, 08:43 AM
Can't find them in the SI catalog. My 4 door needs the metal shims for the back door. I know I can make them, but if you have some older factory ones--better yet. I'm also in need of the split grease ring that accompanies the large nut with the center carrier bearing. I ordered the rebuild kit from SI, and the actual bearing was a little thicker than mine, but it worked just fine. On to rebuilding the rear end. And I'll be done with the underside---YEA.:D
Corvanti
12-10-2013, 03:44 PM
you may want to PM "Roy Valdez" - a forum member in California. he has quite a few parts for bullet noses. :)
