Really, I'm just messin' as this time; don't know how all this will play out. However, I want to get some ATF and diesel fuel into the cylinders of a 51 V8 engine. And, I want to know more.
I've removed most of the small "removable objects" from under the hood, have pressure washed, then air "dried", then sprayed everything with diesel fuel. Now I want to fill the cylinder cavities.
Question 1: When I removed the intake manifold, I noticed 5 large "rectangular slots" going to each of the heads. Okay, 4 intake valves on each side - but why the 5th and center slot?
Question 2: If I fill the slots with diesel fuel, will the fuel fill the cylinder cavity - for those cylinders with intake valves open or even partially open?
Question 3: Do I have to fill at the plugs to be certain?
Going to try and post a photo so y'all can see what I'm trying to talk about.
