I have a 1950 Studebaker Champion 4 dr.
Gravel Guards
The rubber ones are the rarest. No one has reproduced these so far. Stainless doesn't die; it just gets bent and dented. The rubber ones do show up from time to time on Ebay. I would suggest you check with Tom Karkiewicz in South Bend. He had some rubber ones at the Reedsville swap meet in October.
Tom K. (574) 287-5834Brad Johnson,
'56 Sky Hawk in process
My 50 four door has the original ones on it. They are black rubber with four holes in each corner. The rubber outer coating is about an inch larger (all the way around) than the metal plate that fits inside of the rubber. Sorry but you can't have mine. They are cool, good luck finding some. Do you have the books for your car-parts, chassis, body...they helped me rebuild a lot. Rick
