If this were an E-Type Jaguar with Lucas electricals I would shrug and assume it's all normal. Except of course that it might burn down my garage.
Here's the scenario; any input you guys have is welcome.
The car: 1963 Avanti R-1, original Stude engine (rebuilt), new Remy/Nippondenso alternator from Rock Auto wired per instructions on Bob Johnstone's web site. New wiring harness from Studebakers West. Dave T-Bow Chrysler electronic ignition.
Background: Car was a non-running basket case restored over 5 years. This summer we finally got it running. This fall I was able to drive it short distances and commenced troubleshooting the many items I *ahem* screwed up. It has started nicely more than a dozen times and has a nice idle. Needs a choke adjustment and other fixes to prevent stalling, but I digress.
The Problem: I hadn't started the car for a few weeks because there was always something more urgent to deal with. Last night I had some time and tried to fire her up. Primed the carb with a little 93 octane and it turned over nice and hard, coughed a few times but did not catch. Tried a few more times and flooded the carburetor. Came back later and still could not get it running. Eventually the battery started to fade and I gave up. I charged the battery and vowed to return to the fight today.
This morning I turned the key and nothing happened. No click, no crank, complete silence.
Hmmm, says I. I put a test light on the battery and got a nice, bright light. Then I saw the melted wire. The white ground wire from the voltage regulator case to the harness had been fried so hot that it melted and broke. This is strange for a couple of reasons. First, the voltage regulator is ornamental at this point because the new alternator is internally regulated and the wires that went to the VR have been reassigned. Second, what would cause a ground wire to melt?
Please note that at all relevant times today the ignition switch was OFF.
I reconstructed the experiment with a new ground wire and accomplished the same result within seconds of reconnecting the battery. Lots of smoke and melted insulation. I didn't wait for the copper to melt this time; I disconnected the power and cogitated. The ignition switch is off, yet there is power running through to the voltage regulator harness ground.
Hmmm, says I again. I ran a new ground, this time not from the harness, but straight to the chassis. 8 gauge solid copper wire. I reconnected the battery and no smoke came from the new ground. Instead, smoke started coming out from under the dash and in the vicinity of the starter solenoid. I disconnected the battery again, checked under the dash and found that the red insulation on the wire from the output terminal of the ammeter to the input side of the solenoid had melted and bubbled. So the short, if that's what it was, migrated. Battery disconnected and more thinking.
Well this is unusual, I think to my self. I draw a wiring diagram of the affected parts and consulted with my friend Jim, whose disease manifests itself in the form of Porsches and spec Miatas, not Studes, but who generally can think things through pretty well. He focused on what could have happened between last night and this morning, and wondered about mice, but was pretty much flummoxed.
I suppose I'll have to start analyzing each connection but would rather not fry too many more wires before I figure out what's going on.
My first unconfirmed suspicion is that there's a short in the harness somewhere. My second unconfirmed suspicion is that the bypassing of the voltage regulator while still using its battery and ignition posts has caused some unanticipated short.
How would you fellows approach this and what would you look at first?
Many thanks,
Tom
Many thanks,
Tom
