With 4 column shells none of which work, a now beautiful refinished wheel that doesn't fit the center shaft on the car, I'm at the frustration point of starting from scratch with a hot rod column and wheel or a brand "X" from Pull and Save.
I'm at the point of not trusting my eyes or even trusting that the shaft that came on the car won't put the driver in the back seat. I'm open to any thoughts from the experts or those who've been there done that on a column swap. For starters, I could use a reference distance from the firewall to steering wheel center or any other reference of length.... since the Speedster is a PS version where the PS Box is nearly against the firewall, distance to a manual box is irrelevant.
I recall someone mentioning a Grand Am column wheel at C Springs....
Yes, it would be an opportunity to swap to an Astro box but you have to stop somewhere and I really would like to eventually get the car on the road. I'm visualizing a collapsible column, chopping the current shaft near the PS box and connecting to a new column shaft with a "U" joint.
Thanks in advance to one of the smartest boards on the web.
