I just opened the T86 transmission on the bench for inspection.
Because it has stood on the bell housing end for the last 6 months, most of the lube had drained out. But, all components still have a nice protective coat. To my surprise, gears, synchros etc. all look great.... no noticeable wear or chips.
The transmission easily slips in and out of 2nd gear..... however, even with moderate force it can not be put in 3rd gear! I must assume that something is amiss that is out of sight.
Now for the solution...
A thank you in advance to you pros.
- Are special tools required to do a T86 tear down?
- What should I expect to pay for a professional rebuild
- Likely 70,000 to 80,000 miles on it.. Should a bearing etc rebuild be due?
- Is there a simpler, more likely issue?
