Hood Prop retainer Clip?
  • Body / Glass: Hood Prop retainer Clip?
    About 1 out of every 10 times I open my hood and flip up the hood prop, it pulls out of its bottom hole.
    When I look at the Chassis parts catalog I see that there is a retaining clip. I assume that I am missing it.
    I looked the part # up for the clip but SI doesn't have it. Is there a "CASO make do "alternative?
    Phillip
    Post the part number and maybe someone here will have one for you.
    Milt
    1961 Hawk 4-speed
    1967 Avanti
    1961 Lark 2 door
    1988 Avanti Convertible
    Member of SDC since 1973
      Good idea! it appears that the part # is 299777
        Drill a small hole in it. Put a washer and a cotter pin in it. Good luck with the drill! Or run a few threads on it with a die and put a nut on it.
        Neil Thornton
          How 'bout a "push nut", like the ones that hold the wheels on a kids tricycle? They're available at local hardware stores.
          Dwight 54 Commander hardtop
            303662 SPRING,G125619 BODY PLUG,299777 HOOD PROP CLIP,2046X7 DOOR HINGE MOUNT SCREW,15-025 SCREW KIT 1962-1964 GT,15-025A SCREW KIT 1953-1958 K,15-025B SCR
            Third item down the page $4.00
              This should be what you are looking for:
              Perry
              \'50 Business Champion
              \'50 Starlight Champion
              \'60 Lark Convertible,
              \'63 GT R1,
              \'67 Triumph TR4A
                Perry, that's exactly it.
                Skybolt, thanks for the link.
                As to the other ideas, I may try them as well.
                Thanks to all!!
                  The same basic clips are all over the place at a local scrap yard. Easiest way to get correct size is find a small bolt the same size as your hood support... then carry it with you. I imagine most auto parts store would have some close ones as well.
                    I have broken several of those clips trying to install them. No matter how careful I am, I've yet to get one on....I just gave up and do without.
                      I had this clip for a couple of years in my parts stash after purchasing it and could not figure out how it was installed. Finally someone posted a picture of it and put it in within a couple of minutes. As I recall there was a trick to it's installation. I believe you have to install the clip then insert the prop rod.
                      Allen
                      1964 GT Hawk
                      PSMCDR 2014
                      PSMCDR 2013
                      Victoria, Canada
                        Come home please
                        My 1st car. "A TRANSTAR"
                        Starliner
                        Somewhere between Culture and Agriculture
                        in the Geographic center of Tennessee
                          Sorry text got sent to thread I was looking at
                          Starliner
                            The clip from SI fit my '51 but would go on the '53 no way no how.
                            Brad Johnson,
                            '56 Sky Hawk in process
                              Originally posted by Skybolt View Post
                              rarely have I been so pleased with a $4.00 purchase - It works perfectly!
                              Thanks everyone for your help!!
