I'm planning to use gas filled supports to hold the hood and trunk open on the '54 Starliner. Both hood and trunk have springs incorporated into the hinges. I'm not sure if I will need the springs or not, after installing the gas lifts. Given the hokey nature of these hinges, do the springs perform any function when the hood and trunk are sitting there closed, such as holding the back of the hood or front of the trunk tightly closed, or do they assist in keeping the hinges working properly while opening in some way, or better yet, can I just leave them off. Those springs put a lot of pressure on the hinge points, and cause some un-natural forces, that I don't care for. (The plan is to install the gas lifts such that they push forward and up on the hood, and they push rearward and up on the trunk lid.)
Has anyone eliminated them when installing gas filled lifts?
PS (I don't need any comments like "you have to keep them to be stock", or "you will loose points without them", or "why would you want to eliminate them, they worked all these years", or "Please don't bastardize your Studebaker", there is not much "stock" about this car.)
PS/2 The hood is receiving new support material along it's edges, from the hinge end to well forward of the new lift point, and I'll retain the cross rod at the hinges.
