This engine was in a 62 GT Hawk. I am pretty sure its a 289 but the valve covers are red and its throwing people I talk to off, so I am doubting it as well. I tried reading the engine chart here (http://www.studebakerdriversclub.com/V8EngineID.asp) and it says "P followed by a letter and 3 numbers = Hawk/Lark-type 28". However the engraving reads "P82482" so its not P followed by a letter? Thanks in advance.
Is this a 289?
Andres Garcia
Fairfax, VA - Philadelphia, PA
1953 Studebaker Starliner - Check out this project!
1963 Studebaker GT Hawk - Check out this project!Tags: None
You are just misreading the Engine Chart, only Supercharged, Canada, Los Angleles, and '64's have a second Alpha, it does not matter anyway as the "P" tells you it is a 289 and the year matters little as they are all basically the same.
It is a '62 Hawk/Lark 289, I would pay NO attention to Valve Covers that can be easily changed and some early, non-full flow '62's I believe did have '61 Valve Covers, no big deal!
The real 289 proof usually except in the case of a Avanti R1 or R2 Engine would be the Dish or "Bowl" in the Piston Top, easily seen, felt or measured with a Piston at TDC through the Spark Plug hole.
After this many years some 259's and 289's, Pistons and Cranks have gotten swapped around, so it is possible to have a Engine Serial Number that lies about it's C.I.D.!Last edited by StudeRich; 11-12-2013, 11:08 AM.StudeRich
Aw, I guess I don't fully understand how to read this
So does that mean p79-p801... I feel really slow here. I am guessing that I am correct in saying its a 289?P-79,801 1962 Lark/Hawk 62V 289
Andres Garcia
Looks like it could be a '61 289. But, yes, after all these years, until you verify the stroke, you can't know for sure. Judging by the front pulleys, it came from a car with air conditioning.Gord Richmond, within Weasel range of the Alberta Badlands
No, there are no dashes, commas or spaces intended all this is, is a numerical "count" as they were assembled, your's is the Eighty Two Thousand Four Hundred and Eighty Second 289 built and being AFTER 79,801 and BEFORE P-93,601 ('63 289) it IS a 1962 289.
The FIRST Letter prefix only indicates the Engine Size or Series.
OH!!!!! Maybe what you did not read is that these numbers in the chart are the STARTING Numbers for each year!
Read Post #2 again.
I see that "hearsay" can go a long way in confusing people!Last edited by StudeRich; 11-12-2013, 11:09 AM.StudeRich
That is really helpful thanks StudeRich,
gordr, I didn't see any air conditioning equipment, however there what seemed to be a strange second heater core under the passenger seat. I had not seen that before myself.Andres Garcia
That is OK Andres, you are NOT the first and will not be the last person to try to overcomplicate this, it is simplicity at it's best!
The Second heater core on the Driver's side is an Option for very Cold climates like Canada and Alaska or anyone who wants Maximum Heating I guess.
It has no fresh Air going to it so it does not flow as well as the right side one which MUST have the outside Door OPEN and the Inside one Closed for fresh flowing Heat/Air.StudeRich
One thing to remember -
You can come upon a block with nice little numbers stamped in it...that mean nothing..!
My 299 inch Stude engine is just a bunch of parts..
A 259 block with a 289 crank, forged flat top pistons...and on and on, (going into my Champian Conestoga, with a Commander dashboard).
It's "very" easy to come upon an engine like this 50 or 60 years after the fact..!
My early '62 GT Hawk had red valve covers when I bought it used in 1991 but the engine serial was within the '62 parameters.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
The real 289 proof usually except in the case of a Avanti R1 or R2 Engine would be the Dish or "Bowl" in the Piston Top, easily seen, felt or measured with a Piston at TDC through the Spark Plug hole.One thing to remember - You can come upon a block with nice little numbers stamped in it...that mean nothing..! It's "very" easy to come upon an engine like this 50 or 60 years after the fact..!
jack vinesPackardV8
Originally posted by 41 Frank View PostMy early '62 GT Hawk had red valve covers when I bought it used in 1991 but the engine serial was within the '62 parameters.
It was bought new at Phil Rauch Studebaker in North Hollywood by Pete Boaz, a "big cheese" in the H-E-T club. At some point, he sold it to Fred Roth, another H-E-T & SDC member, I bought the car from Roth circa 1970.
I sold it to a relative of Chuck Naugle circa 1973/74, when I tried to buy the car back years later, I spoke with Chuck who told me the guy had moved back to the Philippines taking the car with him.
At about this same time, I also owned numerous 1955/56 Packard's and a 1958 Packard H/T that I bought from the original West L/A owner. I sold this car in 1977 to Jim Swank who still owns it today. I've seen it pictured here several times.Last edited by WinM1895; 11-12-2013, 06:59 PM.
