A while back, I posted need help on machining my intake manifold. I had someone out their who could machine and port my intake. He has a yellow prewar truck. I think it is a yellow coupe express. Can you email me your phone number our email address. I want to send you my intake. I have a Offy that I need to fit on my 1964 full flow block. Roy
Have Aluminum intake manifold that needs to be fitted for Eldebrock 4 Barrel Carb.
As far as that goes, aren't most Edelbrocks still drilled for the Carter WCFB pattern as well? All the older manifolds usually need is just clearancing the secondary bores for the larger butterflies. I've done it with a Dremel.
jack vinesPackardV8
The old Offy has a narrower square bolt pattern than the narrow AFB/wcfb.
The bores really need opening up, and a good radius done to make them work decent.
Port matching helps too.
Adapter plates will work, but it will choke the throttle bores down, and if the adapter plate is too thick, the 'stack up' height can cause hood clearance issues on some Stude's.
The corners need holes drilled in them and a flat surface milled for the corner hold down bolts.
And the Offy can be prettied up, too!
Originally posted by PackardV8 View PostAs far as that goes, aren't most Edelbrocks still drilled for the Carter WCFB pattern as well? All the older manifolds usually need is just clearancing the secondary bores for the larger butterflies. I've done it with a Dremel.
jack vinesHTIH (Hope The Info Helps)
As a side note...
I can make sure you have hood clearance issues on your Stude (with an Offy intake), too
jack vinesPackardV8
If it was an Offy intake for a Stude (without an adapter plate) (like the OP has), it probably took a Rochester 4GC carb, or a Carter 'early' WCFB.
Originally posted by PackardV8 View PostFor what carbs was that narrower bolt pattern intended? The one I had took both a WCFB and an Edelbrock with no problems.
jack vinesLast edited by DEEPNHOCK; 11-11-2013, 06:50 PM.HTIH (Hope The Info Helps)
The old Offy has a narrower square bolt pattern than the narrow AFB/wcfb.it probably took a Rochester 4GC carb, or a Carter 'early' WCFB.
jack vinesPackardV8
You know more than I do, Jack.
I'm just trying to help Roy out, and answer questions.
That's why I posted pictures.
Lot's of info out there on the 'net.
Originally posted by PackardV8 View PostJeff, I'm confused about where you're going with this. Was there an 'early' WCFB pattern? I've used them from '52-'64 and every one I ever had was the same bolt pattern, which was the same as the Rochester 4Jet.
That Packard manifold (pictured) does not have the same base bolt pattern that the early Offenhauser has.
Yes, it does have the narrow AFB pattern, but that pattern is way longer than the early AFB or Rochester that I put pic's of earlier.
The early pattern is a square one. You can see the difference on the Offy's that I put the plates on.
See the countersunk Allen bolts? The other (outer holes) are the later, narrow AFB pattern.
Originally posted by PackardV8 View PostHere's a Packard intake with the same Carter WCFB/Rochester 4Jet bolt pattern as the early Studebaker 4-bbls.
[ATTACH=CONFIG]29554[/ATTACH]
Here's an Edelbrock AFB with both early and late bolt patterns.
[ATTACH=CONFIG]29555[/ATTACH]
As we can see, using the four inner holes it drops right on the early carb bolt pattern manifold.
[ATTACH=CONFIG]29556[/ATTACH]
This should help clear things up a bit. The Stude Offy was designed for the Stromberg 4A Aeroquad used on 52-54 Buicks. Carter also builds a WCFB with the same pattern as the 4A. Here's some pics of my stock Offy with and without an adapter. You can see the big difference between the 4A pattern and the large WCFB/AFB/Holley patterns. I picked up the adapter from Vintage Speed before I found an off the shelf 4A pattern WCFB from a closing parts store.
That's why I asked about the existence of an "early" WCFB bolt pattern. For some reason, I don't have one in the collection. It took some research, but as Jeff says, there were two WCFB patterns. The rare '52-54 square bolt pattern was used on Buick and Packard straight-eights, Cadillac and Olds V8 as well as this Offenhauser Studebaker V8 intake.
The much more common '55-67 WCFB rectangular pattern, the same as the Rochester 4Jet, was used by Studebaker, Packard, Chevrolet, Pontiac, Buick, Chrysler, DeSoto, Dodge, and Diamond T.
(BTW, I've never even seen a Stromberg Aeroquad. By the time I was seeing Buicks, I guess the Aeroquads had all been replaced by WCFBs. and the later cars all had Rochesters.)
Next question, I thought I could remember having an Offenhauser intake manifold with the late bolt pattern. Did Offenhauser change the bolt pattern after '55 when all the OEMs changed?
If it wasn't an Offenhauser, what other Studebaker V8 aftermarket aluminum intakes had the later bolt pattern?
On the shelf or on the cars are a dozen Rochester 4Jets, six WCFBs, eight AFB/Edelbrocks, and they all have the same rectangular bolt pattern. When the AFB came along in the early '60s, they used a wider pattern, same as Holley, but retained the narrow pattern beside it. This was a benefit, because with a few modifications, the AFB could bolt on to 4-bbl manifolds back to '55 but the Holley required an adapter.
Thanks to Jeff for reminding me and we all of the two different WCFB bolt patterns.
jack vinesLast edited by PackardV8; 11-12-2013, 10:17 AM.PackardV8
