I have a 64 hawk R1 power brakes , and steering. stick. I was in heavy traffic the other day and the engine started hissing....then the brakes were hard...I figured I had lost the brake hose and indeed it did come off the carb end. It ran poorly at idle but ran better at high demand. When I noticed this I waited for an opening and then I jumped on it...WOW. Suddenly I had more power...lots more. What can I do to keep that? How can an intake leak give me that much more power.... Is the filter that restrictive? Is this lean out dangerous? I was thinking it might be as I put the hose back on and finished my drive home. Any thoughts???
air and fuel too lean?
Tags: None
lean mix
Originally posted by am not r2 View PostI have a 64 hawk R1 power brakes , and steering. stick. I was in heavy traffic the other day and the engine started hissing....then the brakes were hard...I figured I had lost the brake hose and indeed it did come off the carb end. It ran poorly at idle but ran better at high demand. When I noticed this I waited for an opening and then I jumped on it...WOW. Suddenly I had more power...lots more. What can I do to keep that? How can an intake leak give me that much more power.... Is the filter that restrictive? Is this lean out dangerous? I was thinking it might be as I put the hose back on and finished my drive home. Any thoughts???
"Modern" automotive carbs only have a bowl vent into the air cleaner area. If done well This means the pressure in the bowl is the same as the carb inlet, so filter restriction (by design, or after many miles filling with junque) have relatively little effect on air/fuel ratio.
Was the "lots more power" over 3000 rpm?
Stock R1 Carb?
am not -
Interesting comments...to be sure.
A "lean" mixture, or fuel to air ratio (no big words here..!) will "not" produce more power..OR...more power thAn what..!? The proper or "book" ratio of fuel to air is 14.7 to one of fuel to air going into your combustion chambers. In real life conditions, a slightly richer mixture of 14.9/15.0 is normally more productive, makes the engine happier. Then you need a "much" more rich condition when you step on the gas pedal hard (the "accelerator" pedal), normally upward of 19-1, fuel to air, that ends up back down at your cruse ratio.
So, to not make this into a classroom lesson, all your experience prooves is that you have a carburetor that's setup too rich and maybe ignition timing that's set too low. I'm assuming your'e not overly experienced in this type of tuning, I'd sugest that you search out a "tuneup shop" nearby that has a "chassis dyno". Pay the man to tune your engine. You'll be MUCH happier, your wallet will be happier for the better milage, your butt will be happier because of the increase in power and drivability will make you like a school kid again...!
If you want to know/learn more, there are many books on "how to tune an engine".
Maybe it did feel more powerful to you because of the way an AFB carburetor works. When the throttle is opened wide, manifold vacuum drops, allowing the metering rod springs to overcome the vacuum pull, so they rise and admit more fuel. The manifold leak may have helped the high speed circuit to open quicker, in turn activating the secondaries earlier also. It may have felt good, but as Mike sez, you don't want to run it that way.Restorations by Skip Towne
Originally posted by am not r2 View PostI have a 64 hawk R1 power brakes , and steering. stick. I was in heavy traffic the other day and the engine started hissing....then the brakes were hard...I figured I had lost the brake hose and indeed it did come off the carb end./Cut/
It is supposed to be connected to the Fitting in the Intake Manifold.StudeRich
What I've done with mine (won't go into running problems):
1.) Started using Lucas Oil Safeguard.
2.) Replaced the fuel filter with a Napa Gold 20 micron (old one was full of particles).
3.) Adjusted the carburetor (plenty of videos online & You Tube explaining how).
My GH is now running very good.Last edited by EssexExport; 11-06-2013, 06:47 AM.
Having worked with chainsaws a fair bit, I can tell you they will rev really high when set too lean, but put a load on them that way, and they will dog right out. You want to set the high speed jet so they run a bit rich under no-load conditions, almost to the point where they start "four-stroking". Then, when the chain gets a bite in a log, they smooth out and pull strong under load.Gord Richmond, within Weasel range of the Alberta Badlands
stoichiometric is mass or weight based.
The chemistry is the same at sea level or 5000 feet.
Changes in elevation require changes in jetting ( leaner jetting at high altitudes) because the air density is generally less at higher altitude, but the density of the fuel doesn't change much, and pressure drop in the venturi is not linear when the air mass changes.
the direct approach for accurate tuning is to use a Relative Air Density meter.
No, I am not too well versed in tuning but I can use a timing light and vacume gauge. I know it was set rich. The power was over 3000rpm, yep it hooks tothe fitting on the manifold, I live at about 300 feet elev. or so.
I have thought about going to get a dyno tune locally but I have some reservations. I never have been given strong positive feedback from the locals. I know it would be worth it. The carb is correct and original. Rebuilt a few years ago by pony carbs in NM. Thank you all for your input. R64 GT R1 4sp Hawk
Mohawk Trails Chapter SDC
I'd think at 3000 rpm with a significant amount of throttle my carb has transitioned from the idle circuits (which is what the external mixture screws can change) to the intermediate or even power circuits which are controlled by jets and whatnot deep in the carb's gizzard.
I'd take off the air filter and have a peek around.
Maybe a plugged air filter would not make a big theoretical change in "richness" (except on carbs with vents outside the filter) but a choke that is not straight up when warm sure would.
As others said, a real tune up ( as detailed in the shop manual, not plugs-n-points for $39.95) sometimes finds a lot of lost horse pressure.
