Does anyone know, off hand, if a 56 Golden Hark, (driver side) window regulator will work on a 63 GT Hawk? They look the same but can not figure out from book if it will work. Present GT regulator works but has a rotational "thump" as if a gear tooth is broken. Ken, Deltaville, Va
door regulator interchanchange
Your regulator for 1956 is part #1314353. If the number for the '63 is the same, it will work. What book are you using?Brad Johnson,
'56 Sky Hawk in process
I come up with a 1331717 that says it fits both C & K from 59-63. Why the 64 part carries a different part number is a puzzle to me. All these should interchange. Studebaker should have (& could have) superseded these parts with one number & kept their inventory that much lower=less overhead, more profit, profit they could have used elsewhere.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Warren and Chris hit exactly the point of the original question, i.e. interchange vs correct part number. After nearly 20 years of restoring Studes some parts are interchangeable notwithstanding their part numbers, in fact one vendor said to send part and he will make it work. My first experience (years ago) with this issue was front fender trim in the restoration of a 57 GH and 56 GH whereby I'm told by a vendor, there is a 1/8" difference in length between the two years, a difference not too many would notice. These two regulators look enough alike that the 56 part should work, if not the broken gear will be replaced using the 56GH part or parts. Ken, Deltaville, Va
