A week ago I drove my stock 51 LC about 20 minutes at highway speed to a family dinner. I noticed a couple of times that the ammeter needle seemed to be jumping around. On the way home I had the headlights, the climatizer/defroster fan and the radio all going. My dash lights don't work so I couldn't see in the dark what the ammeter was doing. When I got home and turned the engine off to get out and open the garage door, the starter would only give a small groan but wouldn't turn the engine over. The 4 year old battery was nearly dead.
The next day, I charged the battery and the engine started easily. However, the ammeter was showing nothing whatsoever (no charge OR discharge) even when I turned off the engine and turned on the headlights. Since the ammeter is showing nothing this seems to me to indicate a problem with my voltage regulator rather than the generator. Am I correct?
If it is a problem with the voltage regulator, should I attempt to repair/adjust it or replace it? Neither the VR or the generator are the OEM Delco Remy products so my Studebaker shop manual won't help too much.
Thoughts and suggestions are welcome.
Thanks,
Jim
Thanks,
Jim
