I have about finished the installation of a reverse lockout mechanism for the Hurst Competition Plus 4-speed shifter in my 1959 Silver Hawk. (I'm still making final adjustments, so the shifter boot is not yet screwed down.) The actuator is a modified switch guard that I can engage without removing my hand from the shifter handle. The mechanism consists of a slotted slider 1/8" thick that normally resides between the shift handle mechanism and the rigid shifter body. This slider keeps the shifter in the 1-2 gate. When the spring-loaded actuator is pulled up it raises the slider from its slot, allowing the shifter to engage the R gate.
Reverse Lockout for Hurst Competition Plus Shifter
I'm with Randy on that. I admire your ingenuity, but can't figure out why it would be necessary. I have driven quite a number of Hurst shifted 4 speed cars and never came close to hitting reverse by accident. The ones I had were spring loaded where you had to overcome spring pressure to get into the reverse gate. On the other hand, if it gives you a sense of security, good on ya.Pat Dilling
Olivehurst, CA
Some sanctioning bodies require fitting reverse lockout systems on all shifters (automatic too).Jim
