I have a 53 coupe tank that I had cleaned out a few years ago. I was getting ready to paint and install it but when I blew into fitting no air would pass. I ran a twisted wire cable into tank fitting an d did push something thru but cable stopped when I Went so far. What I want to know is there a "t" fitting on end or should cable go all the way into tank. some air passes thru now but I don't know if it's open enough for good fuel flow. THANKS FOR ANY RESPONSES
pickup tube
If the tank is mounted in the car, how about pouring some solvent like varsol in the tank and seeing how much flows out tube? Don't have access to my computer right now that has my manual/parts catalogue on it, but perhaps that can give you the answer? cheers, junior.sigpic
1954 C5 Hamilton car.
tank
Originally posted by Alexand not to er Feiman View PostI have a 53 coupe tank that I had cleaned out a few years ago. I was getting ready to paint and install it but when I blew into fitting no air would pass. I ran a twisted wire cable into tank fitting an d did push something thru but cable stopped when I Went so far. What I want to know is there a "t" fitting on end or should cable go all the way into tank. some air passes thru now but I don't know if it's open enough for good fuel flow. THANKS FOR ANY RESPONSES
The tank was removed in 2008 and cleaned at radiator shop. No coating or liner was installed in tank. I was getting ready to reinstall it but decided to check flow by blowing into outlet, but little no air passed thru into tank. I ran a wire cable thru outlet found some resistance but eventually pushed cable into tank aprox 16 inches when it stopped. I used fuel injection cleaner and repeated several times alternating with small amounts of cleaner into outlet. The cable stops at same place all the time. I then tried blowing air into outlet but little air blows thru. My question - is their a restriction at end (start) of tube such as a screen or t fitting or is cable hitting a bend and stopping at that point. Thanks for Replies.
That pickup tube extends horizontally in to the tank, then makes a 90 degree bend to the tank bottom. Your probe is simply banging bottom and won't go any further. I would do as Dave suggests; remove the sending unit and try to see if the end of the pickup tube is open.Brad Johnson,
'56 Sky Hawk in process
Hey, gotta try that with my tank. I am having problems with my fuel system & am wondering if there happens to be a (extra) hole in the side of that pickup tube that is sucking air... can it be repaired? Can one unsolider the connection to the fuel line and remove it... or is it indeed spot welded to the bottom of the tank?
