I have a 53 Commander with a 259/4bbl from a 59 Lark. Would anyone know off the top of their heads if an oil bath style air cleaner from a 57 Hawk would fit under my hood? I have a chance to buy one but I don't have the front clip on my car to try it.
Will a 57 hawk air filter fit under a 53 hood?
As long as you are running the '55-'62 WCFB 4 Brl. Low Rise Intake Manifold from a '59, not only will a remote mount '57 Style fit, but so does a Wet or a Dry type on the Carb. style '59 to '64 Air Cleaner also.StudeRich
Originally posted by StudeRich View PostAs long as you are running the '55-'62 WCFB 4 Brl. Low Rise Intake Manifold from a '59, not only will a remote mount '57 Style fit, but so does a Wet or a Dry type on the Carb. style '59 to '64 Air Cleaner also.
I guess it might be tight with a slightly deeper '59-61 Air Cleaner, but my '54 K fits with a AFB and a '64 Dry Cleaner without R3 front Engine Mounts, it also fits with a R1 Air Cleaner but they ARE lower.
The Engine is an "299" R1 1/2, Cloned from a '56 Commander 259.
Who says I am a PUREST?StudeRich
Originally posted by Zenwren View PostI have a 53 Commander with a 259/4bbl from a 59 Lark. Would anyone know off the top of their heads if an oil bath style air cleaner from a 57 Hawk would fit under my hood? I have a chance to buy one but I don't have the front clip on my car to try it.
You'll have room for a flat bottom air cleaner assy, using a 2-1/8" element or a 3" element with a recessed bottom plate.
But you asked about the '57 Hawk oil bath air cleaner. Yes, I think you'll have room.Jerry Forrester
Forrester's Chrome
Douglasville, Georgia
That Mr.Gasket air filter housing looks like a clone of a 67 Buick air filter.Bez Auto Alchemy
Originally posted by Zenwren View PostWow, I thought I was in for some major clearance issues but it sounds like not! What diameter 2 1/8 element were you using?Jerry Forrester
Forrester's Chrome
