Hi there, I have been having a heck of a time trying to find Front brake shoes for my 1964 Commander. First off I bought a set for the front from Autozone and they were 10x2. I need 11 x 2. I ordered a pair that Raybestos listed to fit the car but they don't work either. Has anyone had this problem before? I can't find them anywhere. Any help is much appreciated!! thanks!!
Brake Shoes
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Indeed, the 11 inch shoes up in front, are the ones that you'll need to go to the Studebaker vendors for. The 10 inch rears, cross reference to a Jeep number, and those are still available from the FLAPS. Remember to save the cores for the 11 inch shoes, they can be relined.1964 Studebaker Commander R2 clone
It's been a number of years since those front V-8 shoes were on the shelf. Swap your cores with a Stude vendor or find a local shop to reline them. Whatever you do, if you are disposing of a V8 Stude, SAVE THOSE CORES!Brad Johnson,
'56 Sky Hawk in process
Andy, do yourself a favor. Find a local company that will reline your shoes, turn your drums and arc grind the shoes to fit the drum. If your Commander doesn't already have power assist brakes, you will think it does after having this done.
Using a Stude vendor should be your first choice, but I know of not one offering this service.
Jim Turner should start this service for all the CASO's that won't or don't want to go to discs.Jerry Forrester
Forrester's Chrome
Douglasville, Georgia
Make sure you get 64 V8 shoes as the adjusting arms are different on those shoes and they have an extra hole the earlier V8 shoes did not have. The vendors may have this hole drilled in all shoes, I do not know.Milt
1961 Hawk 4-speed
1967 Avanti
1961 Lark 2 door
1988 Avanti Convertible
Member of SDC since 1973
Yes you need to get the B 177 shoes for the front, B 176 for the rear( same as 6 cyl. fronts). I've gotten them through my local NAPA store. I also have cores if people are interested as I'm cleaning out my garage. Rob in PA.
I'd consult with someone like these guys: http://brakematerialsandparts.webs.c...kerelining.htm
It appears most classic car shoes re-lined today are done with a presumption the car will not be actually driven, so they use liner material very inferior to the original. My experience with the last set of (vendor supplied) 11" shoes, re-lined with modern material, was that they were dangerous at any speed. I bet the guys at the above site could provide a modern liner that would actually stop the car. Worth a try anyway.
If nobody kicks and screams about the inferior liners currently supplied by our vendors, nothing will change. I no longer run front shoes on Studes, but for those who still do, it is a safety issue that needs to be addressed.Last edited by JoeHall; 10-06-2013, 08:20 AM.
I suspect I can find a closer service but all my Stude shoes go to T-bow for relining. Fast turnaround and he knows we drive our Studes. Even made the Rockne feel like new.Brad Johnson,
Originally posted by rockne10 View PostI suspect I can find a closer service but all my Stude shoes go to T-bow for relining. Fast turnaround and he knows we drive our Studes. Even made the Rockne feel like new.
Hi Rob, I am in need of some of those v8 shoe cores. I discovered this weekend that my brother's 1958 packard had nothing inside the left drum when I inspected it. So if you can spare a secondary and primary shoe or a set of fronts, please let me know. If you have also any spare brake parts for the left front. I need to get the brakes functional before the snow flies here. I can rebuild everything later. I am missing the shoes, holdown springs and keepers, all 3 return springs, the adjuster, the long odd shaped part just under the upper springs, and even the rubber adjuster plug. Thanks for anything you can do. Tommy
Tommy, the shoes are the rarity. Everything else is available through the vendors that associate themselves with the Studebaker Drivers Club.Brad Johnson,
