I have a T-86 with OD in a Lark (V-8) with column shift. I found a top loader for this transmission. Does anyone know how to get the shifting forks out of the transmission without taking it all apart. I thought I could pull the pins that hold the side shift shaft and pull it out and then take the forks off, but they don't come out far enough. I took the front flange off and thought I could pull the input shaft out, but it only will move about 3/16 of an inch. The gear is smaller then the bearing, don't see why it won't. Anyone out there that has a slick solution would be appreciated.
Thanks, Gene
Thanks, Gene
